Is the fault with my intermittent driver's side window likely to be a relay fault or not?
Surely if it was a relay the fault would be evident with all four windows? (rs2
Symptoms are what you'd imagine from a faulty relay ie sometimes it goes all the way up, sometimes it stops, sometimes it just works. All other windows work fine. Getting annoying now and I don't fancy having it fail on me somewhere dodgy or on a long trip.
