Hi guys,
I have a problem with my passenger window.
T will go down, but not go up again.
It is the same from the drivers side switch.
I searched on here and found the likely trouble was the switch on the passenger door, as I could check by reversing the switch. Hey presto, window goes up.....
I got 2 'new' (secondhand) switches from idiotguyaudiparts on scambay, and replaced my faulty one... result... the same.... triewd the other 'new' one... same result... they will all make the window go down, but need the wires reversed to make it go back up again...
Can I ask before I go nuts, do I have 3 faulty switches???
How do I get a working switch...?
Any other suggestions gratefully received....
Chris
Chris
