Got my kit sitting on the kitchen table, (Thanks Jas11N) by the looks of things the red and black wires that connects into the car loom and then onto the ballast are very short, in the kit i have 2 longer wires, is it ok to use the longer wires and thred them through the rubber grommet.
If i can't then i haven't really got much wire to play with to mount the ballasts
There should be no need to extend the wiring with Jas11n's kit. I have the same kit in my car and have loads of slack in the wires. The power and earth are fed from the original bulb wiring, so only the cables to and from the Ballasts need to exit the rear cover. Fitting is a piece of ****, other than drilling the 20mm hole in rear cover
I think most people mount the ballasts on the vertical black plastic wing plate, directly behind the headlight, but there is a much better places that only Jas and I (Independently) seem to use....see if you can spot it
Cheers n
Si
95 ABY S2 Coupe - Ragusa Green Subtle mods here and there
2011 A5 3.0 TDi - Lava Grey With every option available (except a towball)
Bolards i totally missed this GB, looked at it on here but can't get on fans to have a butch!
Ragusa Coupe gone!
One other question is it worth getting sidelight bulbs of a different colour to try and match the headlights or not, if so which ones???
Cheers and can't wait til dark, winter does have some benefits!!!
Iain
Enjoy the lights Iain
Previous fitting to S6's saw me mount one ballast to the top of the oil cooler ducting and the other side to the top of the ABS unit. Although there is WAY more space around the engine on S4/S6 it's still suprisingly tight.
I've got these >>> here Picture of them next to 6000k HID's is in this thread >>> here
LED sidelights are also good, again the bay seems to be the place for a good choice.
I'll PM you the details dude.
2001 Avus Silver B5 RS4.
1995 S2 Coupe - sold (sniff)
I fitted the drivers side one just below the wgfv, used the ballast bracket and scewed into a metal cross brace or summit, passenger side straight on top of the abs (cheers for that), although there is more space it's still not a lot to work with.
Iain
hi iain i've still got to fit my 6k set yet but have upgraded main beam with some ice blue bulbs from halfrauds £25.00 for the pair
i'm thinking of upgrading the fogs to 10k aswell just to be different
1. SHORT SHIFT KIT
2. PORSCHE CAYENNE CALIPERS
3. H & R SPRINGS
4. BILSTEIN SHOXS
5. NEW BUSHES AND HP2 STRUTS
8. fmic fitted
Thought about doing the fogs too, i think it would be a bit tight to fit 2 more ballasts and another hole and wiring through the cover, with the hid you really don't need fogs, i decided to adjust my headlights by dropping them down 1 on the electric adjuster and then manually adjust them back up to where they were so effectively i am at plus 1 when the switch is set to 0, when it's mot time i will drop down to position 1 on the switch.
Topsparky? could you PM me mate,
Got a PM off Bry, have replied but no answer.
It asked about dipped and highs for you, but now it seems you already have dipped, don't want highs and want fogs instead?
I'm totally lost off as to what's wanted, if indeed any are wanted at all
Jas..
Jas..
Jas11n
Are you selling HID kits mate??
Whats the story
I want one because my headlights are utter b0llox (as in..I cant actually see more than 1 metre in front of the car in pitch black on low beam!!! high beam is ok)
Though I need to get the headlight mirroring re coated as well!!
Please pm me if you have any kits for sale with price and whatnot...cheers
