heated mirrors and washer nozzels
  • topsparky
    • Oct 2005
    • 2014
    found out this morning that the above was n't working i know it comes on with the hrw
    just wondered if it is seperately fused or seperate relay
    any help would be much appreciated
    going to check wether or not there is 12+ at the connections tomorrow
    thanks in advance oh and
    merry christmas everyone
    1. SHORT SHIFT KIT
    2. PORSCHE CAYENNE CALIPERS
    3. H & R SPRINGS
    4. BILSTEIN SHOXS
    5. NEW BUSHES AND HP2 STRUTS
    8. fmic fitted
  • iain1067
    • 984
    i have just replaced both my mirror glasses (s6) i had 12v or so going to the mirror but no heat, they seem on mine to have some sort of thermo cutout as they aren't on for as long as the timer on the hrw.
    Iain
    • topsparky
      • Oct 2005
      • 2014
      Iain
      my hrw stays on all the time @ least the orange light on the switch does
      1. SHORT SHIFT KIT
      3. H & R SPRINGS
      4. BILSTEIN SHOXS
      8. fmic fitted
      • iain1067
        • 984
        yeah i think from memory my old 90 was like that. if you pull off the mirror glasses pop a multi meter on the wires and see what volts you get, on the back of my drivers mirror (s6) i have a little knob looking thing that i think is a thermo cutout, i doubt you will have that.
        New mirror glasses almost certainly i am afraid, mine were approx £65.00 for the pair.
        Iain
        • GT500
          • Jun 2006
          • 2181
          Have a look at the wiring where it goes into the jet, they get corroded....
          Rob
          Rob..
          87 UR 20v ABY
          97 S6 Avant
          • topsparky
            • Oct 2005
            • 2014
            Rob
            that's what i was thinking it's just been to blood cold
            got some second hand s6 mirror today oops did n't realise
            that they are a different shape
            1. SHORT SHIFT KIT
            3. H & R SPRINGS
            4. BILSTEIN SHOXS
            8. fmic fitted
            • HPmuirt
              S2Forum April Fool
              • Apr 2005
              • 3014
              I am pretty sure that the heated jets are not on a timer, but are always on when the ignition is on.
              The heated mirrors run on the same switch circuit and fuse as the heated rear window, therefore on earlier cars, such as my 2.8 Coupe (MY93) the hrw stayed on all the time, so did the mirrors, where as on my MY95 S2, the hrw and mirrors and on a 9 minute timer.
              I have had several mirrors stop heating over the last 15 years of Audi ownership and on every occasion it was the element in the glass itself. If one is working, try swapping the glass over, coz I bet ya that it will work on both sides, proving that it is the heater element that is faulty
              Cheers n
              Si
              Subtle mods here and there
              2011 A5 3.0 TDi - Lava Grey
              • topsparky
                • Oct 2005
                • 2014
                Cheers n
                Si
                cheers si i thought they were on with the hrw will check them 2 morrow
                1. SHORT SHIFT KIT
                3. H & R SPRINGS
                4. BILSTEIN SHOXS
                8. fmic fitted
                • pastures16
                  • 2058
                  jets do come on with the igntion thats why the burn out
                  94 s2 avant
                  aoc member 1116
