Charging Volts At Battery
  • iain1067
    • 984
    Quick question is 14.25 volts ok at the battery, this is with everything off i.e lights etc
    Iain
    Yes thats fine by my accounts.
    • caterpillar
      • 2480
      its to low... when the engine running, and charging the batt: with the lights on , and the heather fan on 14,4 volt min; THATS ok......!! no jokes for sure.
      • topsparky
        • Oct 2005
        • 2014
        the voltage for charging has to be more than the cell or cells being charged
        the voltage you have there should been o.k but i would check with lights ,heater
        heated rear window etc then check the voltage again with the engine running @
        2500-3000 because the alternator does not charge the battery on idle engine speed
        1. SHORT SHIFT KIT
        2. PORSCHE CAYENNE CALIPERS
        3. H & R SPRINGS
        4. BILSTEIN SHOXS
        5. NEW BUSHES AND HP2 STRUTS
        8. fmic fitted
        • iain1067
          • 984
          Thanks guys will do
          Iain
          • Graham
            • 1622
            I was told in Adelaide mine was not putting out what it should, when the engine is running i get 13.7-14 volts top, with as much load as possible on this is 12 volts. What is on its way out to cause this, is it just a regulator, or a re-wind/overhaul required.
            • s2dude
              • Nov 2005
              • 1631
              I have same problem mate.
              Could be regulator, new alternator, bad connection from earth strap to alternator or earth straps to engine or a poorly battery??
              Im pondering whether to get a new battery for mine for a kick off!!
              • topsparky
                • Oct 2005
                • 2014
                i'd check regulator and bushes
                i don't know if they are serviceable on audis though
                1. SHORT SHIFT KIT
                3. H & R SPRINGS
                4. BILSTEIN SHOXS
                8. fmic fitted
                • pastures16
                  • 2058
                  bushes are service parts 068 903 803d
                  94 s2 avant
                  aoc member 1116
