Diff lock switch
  • Diff lock switch
    I need to replace my diff lock electrical switch on the central colum as it has corroded badly .
    are they the same through all the 80,and 90 range
    or are they unique to the s2 in any way
    Same. Black/yellow stripe that goes to diff lock module needs +12v to acitvate diff lock.
    1989 Audi 80 Quattro
      This gallery has 1 photos.
        This is the part I am looking for
          Sry misread. B3 and prefl coupe have this switch.
            My diff lock switch is down near the handbrake .
            Is yours above the radio?
              Mine is also down near the handbrake .
                They all are near the handbrake, just different switch on B3 vs all the others.
                  Lou, I have a spare switch like the one in my 3B but It’s different to that one. I know yours is an early 3B, can you take a pic of it in its location? Or a pic of how it fits?
                    Sorry bud, I’m an idiot, my 3B is the same switch as yours. The spare switch I have is for the Avant!
                      the early type is a bigger switch, the later one is smaller, but can be used, it will just not fit the cutout in the centre console..
                        I’ve got a box full of switches here, if I can find one that’s the same then maybe you can swap your top over on to it.
                          Thanks John I will get some pictures and a look for a part no , The car is not here, its a few miles away being worked on
                            You can use an ABS switch also. Probably easier to find. Add a bulb, a collar and top cover from your old switch. Bulb and collar are needed for that orange triangle indicator.
                            • #15
                              Lou, I’ve got a spare ABS switch to convert as above
