Hi,
Having a bit of a strange problem on a ABY S2. The Purple fuse for the Coils (S32) suddenly blows randomly. Have tried both new style TFSI coils and the OEM coils with the same result. Changed the ECU as well without any change. Seems like its happening when the engine is warm. The strange bit is that when the fuse blows, and it could happen even when the car is at idle, it keeps blowing until the engine has cooled off a bit. Then the engine can run for hours again before it happens, or minutes.
Any hints? Could faulty coils or bad earth connection cause this problem?
