Managed to snap 2 this week am I tightening them too much
Alternator belts failing
Originally posted by Rikki Kitto View PostCheers peeps how much slack should i have about 10mm maybeNothelle S2 Avant
Using a slight shorter one as the tensioner I use is at it's limit with an 890cm belt so dropped to 878cm, the last one that snapped however was from TPS so would of been the right one. Looked under the car just now and the remains of the last one were wrapped around the pulley stripped to the wire, nightmare getting it all off
I thought I was daft, out in the shed working on the bike
How many daft points do I get for fitting heated grips on an R1M
