Earth points
  • Earth points
    My wiring loom nearly melted itself last week and advice says it maybe bad earth connections, has anyone got a wiring diagram for my sparks man to use or pics of where to look for the main earth points on ABY Coupe'
    S2central.com has plenty of wiring diagrams
      Cheers any links I can't seem to find them
        Can't post a direct link but http://s2central.com/main_frame.html. On the left margin click Technical Data -> then up right Electrical Systems -> Current flow diagrams -> scroll down to bottom of page to S2 / RS2 Wiring Diagrams -> select s2 coupe and go from there. Hope this helps
            Doesn't the site work?
              Yes bud just me not having the required knowledge to work it all out, sure my electrics man will make sense of it all thanks for the help
                Hopefully he will get it sorted
                  Not using the car until it is, frightened the life out of me. Last thing I want is the car going up in flames
                    A runaway meltdown situation is not a nice thing to experience. It was a different car but a con rod popped out through the side of the engine block and as if that wasn't bad enough - it severed the main battery cable to the starter which then shorted out. ​​​​​​
                    The fizzing noise and cloud of acrid white smoke was very alarming.
                        Did you get a copy of the schematics for tablet?
                        Good Idea to check all fuse sizes are correct.
                        Attached S2 central info on headlight washer unfused circuit.
                        headlight_washers.pdf
                        This gallery has 1 photos.
