ABS warning light comes on
  • quattro estate
    • Aug 2015
    • 190
    Hi to all
    the amber warning light comes on after travelling a short distance but cancels out when switching ignition off before driving it again.
    can anybody tell me what the blips mean if i check the defects via the fuse box and where do you connect the blip bulb tester.
    cheers for any info.
    • quattro estate
      • Aug 2015
      • 190
      • quattro estate
        • Aug 2015
        • 190
        Hi to all...
        had the S2 fixed today, no electrical fault, the reluctor ring had started break up on the right front cv joint. However, an easy fix it was not, the new cv with a new ring attached was slightly different and wouldn't fit into t he hub. Put the new ring on the old cv and all is well now.
        • shorty_94
          • Dec 2015
          • 60
          The single ring is available on ebay. I bought two oft it and assembled it some years ago, without any problems until today.
          '95 Audi S2 Avant
          '92 Audi Coupe T89 quattro 2.3E
          • quattro estate
            • Aug 2015
            • 190
            • quattro estate
              • Aug 2015
              • 190
              Thanks for the reply
