I have a issue in the Coupe with the Cluster. The Speedo doesnt work and stays at 0 the Odometer doesnt move and the trip computer is stuck on 200mpg.
I checked all the wiring at each location from start to finish and had continuity throughout so all good there.
I then swapped the cluster from my Avant on to the Coupe and everything worked fine speed registered Odometer started reading again and the MPG was no longer stuck at 200.
Has anyone experienced this and what could the fault be ? I had my cluster refurbed not long ago which included a full circuit board refurb and new MPG and clock displays.
I have opened up the cluster and everything seems intact so where should i look ?
