A wee bit off topic but here goes
On my 95 Cabby I have the factory alarm operated from the key (no remote), presumably the same system as on the S2. Anyhow, the drivers door lock recently stopped activating the central locking and turning the alarm off. With a bit of trial and error I've worked out that there is a switch on the door lock barrel with a grey wire down to a connector by the central locking actuator in the door - if I disconnect that connector the locking starts working again but the alarm no longer works, so I assume the 'switch' on the lock barrel turns the alarm on or off. So to the question (at last!!) - Does anyone know if the 'switch' on the lock barrel is coded to the key or if it is a simple switch that can be changed easily?
For a microswitch
And i thought my S4 was pricey for parts
