on the ellipsoid head lights on main beem is the round light ment to be lite up as well or is it just on dip beam?
head light quiry
Tags: None
as I'm about to pickup my ellipsoids this weekend
how do the current colour coded strips below the early lamp hook up to the later ones....a doddle or a blue peter moment with glue, cutting etc?
1992 3b S2 CoupeComment
Should be the same I think. My S2 had 3b Lights when it was born but the previous owner upgraded to elipsoids. Should bolt straight on...
See you later.
Cheers,
Steve.The Perfectionist
If you have the two seperate strips (one either side) then no difference.
IIRC the very early S2's had a one piece strip all the way across (similar to the B3 strip) that stepped back slightly behind the grille. In that case I think you need to remove a mounting (the fragile corner one) from the headlamps. I think you should be ok on a 92 though. Audi dumped it as most of the strip was a waste.
Stu (4wheeldrifter) is the man to ask.2001 Avus Silver B5 RS4.
1995 S2 Coupe - sold (sniff)Comment
yeah i have the later early lamps
with the strip just under each light rather than the long one.
Cant wait to get them plugged up and then start the HID route
hopefully wil be able to see while driving at night....
Good description Jas.If you have the two seperate strips (one either side) then no difference.
I originally kept the one piece trim when I changed to ellipsoids, by cutting off the mounts on the headlights.
Then I changed my mind and got another set of headlights and bought the two piece trims.
Although now I think the one piece trim looked neater, but I’m not changing the headlights again.
Besides, the two piece trims are a lot lighter as they are made from plastic not metal.
SSComment
i am just trying to change the wires around in the plug to get the headlights to work correctly like in the link but there allready is a wire in number 8 position is this swaped in to number 7 or joined with the ofef one and what is its service?never set your expectations to high that way you are never disapointedComment
i've got a pair of the trims in ruby red if anyone wants them
for a small fee
1. SHORT SHIFT KIT
2. PORSCHE CAYENNE CALIPERS
3. H & R SPRINGS
4. BILSTEIN SHOXS
5. NEW BUSHES AND HP2 STRUTS
8. fmic fittedComment
