2ndary dial diameter/boost guage idea
  • dan_b
    • Sep 2003
    • 3670
    Anyone know (or could measure) the diameter/size of the secondary dials?
    Has anyone tried taking out the alternator voltage charge dial and replaced it with a boost guage? What size guage would be needed to fit in the vacant orifice?
    A boost guage isn't really an upgrade, is it?
  • AbsS2
    • 285
    i think greg did something like that .. http://www.s2forum.com/forum/showthr...5&pagenumber=3
    Coupe
    • porkkis
      • 1994
      The gAUges are 52mm. Whats this gUAge thing?!
      • dan_b
        • Sep 2003
        • 3670
        Blimey, having my English spelling corrected by a Finn, how embarassing! :eek2:
        Thanks Porkiss - I've seen a boost gauge that is 55mm diameter - that's going to be a bit tight to fit down in the place of the volt meter isn't it?
        • porkkis
          • 1994
          Yes it probably would as the front panel is a separate part that has the holes for the original units.
          VDO is the original manufacturer and they have -1 - +2 (or 1,5 can't remember) bar boost gauges available, but they're black. D&W and some other styling companies sell different colour sets so they could probably be converted white, BUT the original ones are light gray so white one would stick out. They could all three be converted white and that would probably be the best solution thinking esthetics.
          IMO the boost gauge is quite useless but good if (when) you run into boost problems. I borrow my friend's industrial type gauge and put it with a t-piece to the MAP hose when I need a boost gauge.
          After all when you step on it you don't have time to look at the console gauges and all other static installations (wents, on dash etc) are somekind of compromises.
          • dan_b
            • Sep 2003
            • 3670
            This looks good value if you're after a white boost guage?
            http://cgi.ebay.co.uk/ws/eBayISAPI.d...ayphotohosting
              • 12431
              http://www.egauges.com/ do the OE style VDO white boost gauges. Upto 1.5bar AFAIK.
