Central locking on S2 Avant stopped working..
  • shark_90
    • 1475
    I have a '94 S2 Avant which has a VDO "Comfort lock" remote central locking system. I locked the car last night (or at least I thought I had..) and now the central locking won't secure the car. What makes it worse is the door locks appear to be disconnected, so I can't lock the car via the lock barrels with the key.
    If I push the plunger down on one of the doors, the central locking doesn't activate, so I can't even lock the car by pushing a plunger, exiting the car via the boot and locking the boot manually.
    If I push the lock plunger down on my 80 Avant the locking activates and locks all the doors, however I don't know if the fact that the lock plunger doesn't activate the locks in the S2 is down to the central locking mechanicals not working, or that something may have been changed with the mechanisms as the door locks are disconnected.
    Does anyone have any ideas on where to start looking? I've looked in the driver's door for wire taps to the central locking and I've found 2 taps but neither appear to be to the locking wire that I know about (green/blue).
    I guess for now I can lock all the doors manually and climb out through the boot, but it's not exactly ideal for day to day use!
    Any help appreciated
    1994 Audi S2 Avant - in pieces
    2006 Skoda Octavia vRS 2.0TFSi - goes fast
    1985 Audi 90 quattro - is wet
    Don't forget the East Midlands Meet -Last Tuesday of every month at 7:30pm just off M1 J28!![/COLOR]
  • shark_90
    • 1475
    OK so the car appears to blow fuse 19 randomly when it's running. If I change the fuse, the locking is fine until I drive the car, and the car won't lock again.
    Hmm.
    • Jas11n
      • 5067
      Checked the wiring inside the rubber boot that connects the door to the main shell? Often hear of degradation on the wiring here due to opening, closing the door etc (same as the taligate)
      Could be a short somewhere.
      Just a thought.
      Jas.
      2001 Avus Silver B5 RS4.
      1995 S2 Coupe - sold (sniff)
