Driver's side front fog light not working.
  • Heat Seeking Missile
    • Jul 2007
    • 658
    I replaced both my front foglight units earlier today. Before, they were...
    Drivers side: Smashed lens and not working.
    Passenger side: Some water in lens but still worked.
    After replacing them, I've now got....
    Drivers side: Still not working.
    Passenger side: Fine.
    I'm about to go out and buy a new pair of bulbs for them and see if thats the problem and I've been unlucky to have 2 bulbs in the same unit that are duff.
    If this still doesn't work, what could the problem be? I'm an absolute noob with electrics so please be gentle
    Mark
    '93 Brilliant Blue Audi S2 Avant - Broken again.
    '98 Tahiti Blue Rover 216SE Coupe
    '96 Arktiksilber Metallic BMW 525td (E34)
    '01 Dark Green Jeep Grand Cherokee 3.1LTD
    '97 Polar White Vauxhall Vectra 2.0Di LS
    '96 Alpine White Peugeot 306 XLDt
  • panzerwagen
    • 900
    Sure fire way of testing wiring for foglites.
    You say you have one working....use jump wires to connect working harness of one to fog lite that is not working. If the foglite works, than it is not your lite but the wiring to it.
    If it still not lites up, take good unit and connect it to the wiring in question. If it lites up it is not wiring but fog lite unit. Process of elimination works every time.
      • Jul 2007
      • 658
      Cheers fella, I'll have a crack at that, didn't get the chance to buy new bulbs today anyway. Went and bought a TV instead!
      Mark
