The car is alive
  • smudge72
    • Apr 2005
    • 53
    The car is alive
    Can anyone help please!!!
    It started on sunday when my hazard lights starting to flash for the alarm when it was outside my house, so i went outside unlocked & locked it again to reset the alarm. It happened again so i started the engine for a while the turned off the locked it.
    I the morning i went to start the car as normal & it was flat as a pancake just a gimmer of light for the battery on the dash, so i thought that the battery had gone so i bought another connected it up (live 1st then earth) & when i did all the lights on the dash turned on without the keys being in the ignition so i disconnected & put earth on 1st then live then hay presto it was ok .The next day i drove to work as normal (everything ok), then i left to go home went to put the key in the ignition & all the dash lights where on without the key in, so i went to start the car which it did but it turned itself off straight away so now the battery is disconnected & i have no car can anyone HELP PLEASE
  • topsparky
    • Oct 2005
    • 2014
    check the ignition switch matey
    a bit of a weak spot with the age
    of our cars i'm afraid
    1. SHORT SHIFT KIT
    2. PORSCHE CAYENNE CALIPERS
    3. H & R SPRINGS
    4. BILSTEIN SHOXS
    5. NEW BUSHES AND HP2 STRUTS
    8. fmic fitted
      Or water in the multiplugs on the firewall. Or in the fusebox.
      • Knight Rider S4
        • 3541
        I would go for the igntion switch as topsparky stated
        93 S2 Avant Parting
        91 URQ RR
        02 A4 tdi Avant
        • Durbs
          • Dec 2007
          • 1
          This happened to me last Christmas, thought the car was possessed. For me it turned out to be a dodgy connection in the fusebox.
          • smudge72
            • Apr 2005
            • 53
            Cheers for that topspary.
            is there a way of testing the ignition switch before i buy a new one!!!
