got a problem
  • strapper
    • Dec 2007
    • 170
    got a problem
    I was doing the coilpack/sparkplug/helicoil repair to the s2 the other night and after I got everything all back together started the car and everything was ok. I left it until the next day before I was going to take it out and when I started the car to take it out the garage it ran ok again then I noticed that the wires from some of the existing coilpacks had bare insulation where they come out the back of the coilpack cover and they were smoking and sparking due to making contact with the cylinder head then the car cut out
    I taped up all the bare connections and covered with heat shrink insulation but the car won't start now, it just turns over sounding healthy though.
    Any ideas as to what I should be looking for?
  • iain1067
    • 984
    I wonder of the ecu fuse has blown or another fuse maybe
    • Fat Audi 80
      • 10547
      Fried Power Output Stage(s) ?
      I would suspect though it would run rough though unless you have damaged both of them.
      Are the POS fused?
      More questions than answers, sorry!
      The Perfectionist
      • GT500
        • Jun 2006
        • 2181
        Deffo fuse, the separate "motor" one.
        Rob..
        87 UR 20v ABY
        97 S6 Avant
        • strapper
          • Dec 2007
          • 170
          Are the POS fused?
          What are the output stage?
          What are the pos?
          • strapper
            • Dec 2007
            • 170
            Where will I find this?
            • strapper
              • Dec 2007
              • 170
              sorry for sounding helpless people LOL!
              • Fat Audi 80
                • 10547
                Power output stages are mounted on the bulkhead and provide the supply to the Coilpack as directed by the ECU signal. There are two each with three outputs. One powers 2 coilpacks, the other powers 3 coilpacks. (The one doing 2 coilpack has a spare channel).
                There is a component finder diagram on the Forum somewhere which might help.
                Cheers,
                Steve.
                The Perfectionist
                • s2_bo
                  • Oct 2005
                  • 6067
                  Yeah sounds like the fuse. Open the fuse box and you'll find it under the little RED cover that says motor on it.
                  Check them both. I bet one is blown.
                  Good luck
                  91 S2 coupé - RIP
                  98 S8 - Luxury barge
                  • ericd
                    • Nov 2003
                    • 1240
                    just remember removal of the two fuses will wipe the ecu errorlog, just in case you're wanting to double check with vag-com, as bo says they're both held together under a little red cover at the front of the fuse box
                      Guys - PLEASE before asking question like this - SEARCH the forum and chase sites like www.s2central.net for technical info. They won't always give you the answer in one go, but will at least allow you to better form your technical questions on the forum.
                      I will make an effort to compile something like a Motronic fault-finding guide but its going to take a while.
                      • strapper
                        • Dec 2007
                        • 170
                        those fuses are ok I checked them straight away
                          What are the pos?
                          This AAN Power Output Stage (POS) info should help for your car:
                          http://forums.audiworld.com/s4s6/msgs/149771.phtml
                          and
                          http://forums.audiworld.com/s4s6/msgs/83085.phtml
                          For what its worth, the shorting bare wires at the back edge of the coil packs should have killed the coil fuse(s) so I can't see how you found them to be okay.
                          Dave F.
                          • strapper
                            • Dec 2007
                            • 170
                            If the pos has failed how much are they to replace?
