DO NOT ADJUST THIS as you will mess up the needle position at full and empty!!!!!
How to....change the speedo clock
This is a sticky topic.
Why is it that you can't adjust the knob when the clocks are back together. The end of the knob just spins freely and I find it a right PITA!!!!!!!!!!!!! -
Acidburn was right on the tip
To adjust the fuel gauge with the clock in position you must take/pull off the ending part of the knob the adjuster it's inside and you need a phillips screwdriver or a very small allen key (can't remember which right now)
With the clocks motherboard out of the facia you can turn by mistake the adjustment wheel and mess with the gauge setting (that can afterwards become a major pita!) hence the suggestion from Acidburn.
StefanoComment
