3b..
Same problem here, windows + sunroof dead but on a 3B. Found this thread, thank you Forum
The double size relay (or control unit) had a different p.n. looked like in the pic. Clearly visible was a bad soldering due to heat cycling, or so it looks to me. Repaired with a piece of wire as reinforcement, repaired a few other bad solderings and it's all good again (fingers crossed)
A few minutes soldering, and now everything works just fine again.
