vagcom AGAIN
  • s2martyn
    Banned
    • Apr 2008
    • 408
    vagcom AGAIN
    after my recent post about the ebay lead with vagcom,i bought another one..it lasted all of 2 days...so i am back to square 1 ...does anyone know of a good quality one that will not pack in after a few goes?or will i have to bite the bullit and get a proper job from rosstech?
    would prefer to get aftermarket one as i allready have the licence info which allows me to use all the functions,but cant keep buying cheap crap..
  • martinjs
    • 3205
    My alpha-bid ebay lead works fine, a few others are using one on here also.
    • s2martyn
      Banned
      • Apr 2008
      • 408
      thats the same one i have been using...it must be ok for part time use,but for everyday usage it is no good...i have had 3 now and the last one bought only on thursday is now knackered ...it says on the test facility in vag com" port ok interface not found!"
      • spink
        • 4382
        i have had mine(alphabid) for about 2 years now and it gets a lot of use(mainly audis but also vw/seat/skoda),i used to have the original ross-tech gear but sold it when i realised that this does the same job for 10% of the price.I have heard of certain cars 'blowing' cables,something to do with the 'k-line' short circuiting the interface.
        • Jonas_R
          • 3781
          • Country: Denmark
          www.obd2000.de or www.vagproduct.com
          Both work great Currently using the one from obd2000 with a 2x2 adaptor for my s2 and other old cars and I use the cable from vagproduct.com on newer cars.
          Sleeper S2 Avant +450
          A6 Avant 2.7t Stage 3
          Audi S2 Coupe RS2'ed
          • Knight Rider S4
            • 3541
            http://www.ecutool.com/myclass.asp?s...m=0&classid=94
            This is the place i have got mine..arrived in 2 days of ordering it..good service
            93 S2 Avant Parting
            91 URQ RR
            02 A4 tdi Avant
              Yep ecutool is the one I use and I have shouted about to the forum
              • s2martyn
                Banned
                • Apr 2008
                • 408
                is the lead as pictured? ie black and not the crappy blue ones?cheers for advise
                • GT500
                  • Jun 2006
                  • 2181
                  Martyn, It could be your ross tech software, My friend had this, use a non ross tech lead and their software it fries it! works as you say a couple of times then shafts it!
                  Use an older version of the ross tech and its fine.
                  HTH
                  Rob..
                  87 UR 20v ABY
                  97 S6 Avant
                  • s2martyn
                    Banned
                    • Apr 2008
                    • 408
                    i have been using the software on the cd together with a crack code for the licence..is this right or should i download from ross tech?or is it the licence crack?
                    • Jonas_R
                      • 3781
                      • Country: Denmark
                      I have found that some of these cables does not work with never version of Vagcom.
                      Try version 3.11N.
