I will have a look on Monday, I have a day off looking after my daughter. If she stays still long enough I may be able to take a look.
Anyone got the part number of the switch handy?
Cheers,
Fatty
The Perfectionist
Other note to self - you don't HAVE to post in every thread just because you can and/or have some mindless comment such as 'I can't really help you on that, but good luck fixing it'. Sorry if thats harsh but it comes across that way sometimes...
Please don't let that dampen your enthusiasm for the S2 Forum - just that when you post make sure your info is helpful and that it has a point (other than escalating your # posts tally).
I think that is a good general point Paul is making. We do suffer from posts having incorrect information in them sometimes.
The Perfectionist
Ok, access to the switch seems to be pretty easy. (even with the air box still in)
But shorting the terminals on the connector doesn't turn on my reversing lights...
Correct me if i'm wrong:
1. One of the terminals on the connector should have 12v on it.
2. The other terminal should have continuity back to the reversing light.
Right?
John Bowlerwell
Electronic Engineer
Present:
Nogaro Blue RS2 - TOE
Previous:
Kingfisher Blue S2 - UAA
Volcano Black RS2 LHD - DEX
With reference to this for a 94 Avant - F4 is the switch in question - you should see +12V at the blue/black wire always - then when the switch is closed that makes its way along to the reverse lights.
Fuse 12 is in play here - lots of other things protected by it... Like parts of the instrument cluster and illumination for console switches such as foglights, heated rear window etc
Still having problems uploading photos to putfile.
Where else can I use?
Hi,
Put the photo's on your desktop
then "Go advanced" on post reply box
Click "Manage attachments"you can then up load up to 5 photo's into the thread...!
Cheers,
Steve.
The Perfectionist
The Perfectionist
