My ambient temp readout gives me an E most of the time, and sometimes (not often) the temp. When I do get a temp readout it starts at 60 degrees C and then drops to more or less the right temp.
I had a look on s2central how to test the sensor, but I can't find it behind the left headlight - but then I also have no clue what I am looking for
My car is a 95 ABY Coupe with manual aircon.
Has anybody else had this problem before? Where do I find the sensor and what does it look like?
Tonight I have to replace the bulb behind the clock - anything I should check for on the instrument cluster while I have it out?
My car is a 95 ABY Coupe with manual aircon.Has anybody else had this problem before? Where do I find the sensor and what does it look like?
It also takes about 30 seconds after switching on the car before it gives the readout.
