What noises do your seat heater relays make? My drivers side one has started clicking a lot when up to temp, it used to just make a buzzing noise occasionally as I think the passenger one still does, is this a relay problem or a seat element problem? Or switch perhaps?
Noises from seat heater relays?
Tags: None
My passenger one does exactly the same John, clicks really quickly once up to temp... seems worse on the more usual 2 or 3 settings..... i've not got around the pulling it out to investigate yet - was planning on swaping them over to see if its the seat / switch or the relay thats to blame... pretty sure its the relay thoughPanthero Coupé quattro 20vt
Hehe nice
I'll try swapping the relays later on.
Yes, I understand the principle except the pasenger one clicks occasionally, actually more like a scrriitch noise, where as the drivers one clicks all the time once up to temp and it didn't use to do this
