Help!
Been following old threads by NEWSH and S2 ANT and seem to have reached the limit of my understanding!!! (quite quickly)
Central locking not working at all - all locks working independently on key.
Have got to the point of checking all actuators - seem ok and now looking at the controller.
Same as NEWSH it seems the compressor motor is getting +/- 12v when i operate a door lock actuator but motor does not run to create pressure/vaccum.
Car has orginal factory alarm still in it somewhere and an aftermarket Clifford alarm - everything USED to work fine either manually lock/unlock or using key fob but stopped working a few months back.
Has the motor been inhibited in some way or is it simply knackered?
Not sure about NEWSH's finding of getting right voltage but not enough current - understand the theory but not sure what to check next!!
Thoughts?
Thoughts?
but is this as good a bet as i'm likely to find???
