ABY battery box cover & fuel filter bracket v
    Will hopefully be fitting an ABY battery box while my car is stripped
    Can anyone help me out with the part numbers for the ABY fuel filter bracket and the battery cover for under the rear seat?
    Alex
  • Acidburn
    • 13459
    I'll have a look in a mo alex, i'll also be needing those bits for when mine is done.
    • HPmuirt
      S2Forum April Fool
      • Apr 2005
      • 3014
      I've always wanted a battery cover as well but the only ones I have seen are those fitted on the V6 cars which have the groove for the expansion bottle overflow pipe and are therefore definately not ABY ones.
      Cheers n
      Si
      Subtle mods here and there
      2011 A5 3.0 TDi - Lava Grey
        Si this one apparently goes on top of the battery to insulate it from the rear bench - you should have one on yours
        • HPmuirt
          S2Forum April Fool
          • Apr 2005
          • 3014
          Eggzachary....but mine is missing
          Trouble is, every time this is discussed, the only one that anyone ever has a picture of is the V6 engine bay battery cover, not an ABY underseat battery cover.
          Cheers n
          Si
            Jas11n posted up a pic IIRC
            • Acidburn
              • 13459
              Cheers n
              Si
              And there was a couple of people at the meet in scotland who had one there when I was chatting to them, apparantly same problem happens with urq's
                OK had a search and found the thread where Jase had posted pics
                Part number for the battery cover looks to be 895 915 411 - I'm going to try and order one tomorrow and see what the damage is (£££ or NLA no doubt )
                Pete - if you need it for your conversion the retaining bracket for the ABY battery box looks like 811 803 739, again dunno the damage or if its still available though
                Done some digging and I think the ABY or LHD S2 bracket you can see on the second to last post of the thread linked to above is in two parts:
                The upper carrier I think is 895 201 447
                The retaining bracket I think is 895 201 679
                Can anyone with the FA confim these are right?
                • neebover
                  • May 2005
                  • 359
                  Battery Cover - 895 915 411 - Vag Parts approx £10.00.. hope this helps
                  Chris
                  Missing her lots!
                    Thanks Chris, i'll see if I can order one up now my ABY box in en route
