I've always wanted a battery cover as well but the only ones I have seen are those fitted on the V6 cars which have the groove for the expansion bottle overflow pipe and are therefore definately not ABY ones.
Cheers n
Si
95 ABY S2 Coupe - Ragusa Green Subtle mods here and there
2011 A5 3.0 TDi - Lava Grey With every option available (except a towball)
Si this one apparently goes on top of the battery to insulate it from the rear bench - you should have one on yours
Eggzachary....but mine is missing
Trouble is, every time this is discussed, the only one that anyone ever has a picture of is the V6 engine bay battery cover, not an ABY underseat battery cover.
Cheers n
Si
Cheers n
Si
And there was a couple of people at the meet in scotland who had one there when I was chatting to them, apparantly same problem happens with urq's
Part number for the battery cover looks to be 895 915 411 - I'm going to try and order one tomorrow and see what the damage is (£££ or NLA no doubt )
Pete - if you need it for your conversion the retaining bracket for the ABY battery box looks like 811 803 739, again dunno the damage or if its still available though
Done some digging and I think the ABY or LHD S2 bracket you can see on the second to last post of the thread linked to above is in two parts:
The upper carrier I think is 895 201 447
The retaining bracket I think is 895 201 679
Can anyone with the FA confim these are right?
