ok here's a wierd gremlin
  • s2driveruk
    • 12696
    Thought i'd take the car out last night as the carpet was out along with the interior to see what difference it made to the car (quite significant actually ) and what i thought was a cluth wearing/noisy thrust bearing seems to actually be a wierd electrical noise coming from under the drivers side dash.
    Under load it seems to make a loud crackly kind of hum and then off throttle is sounds like a sort of electrical version of a scraping/clutch wear noise. I'm 99% certain its not clutch but absolutely no idea what lives under the dash (maybe on the relay plate/secondary fuse board) which would be sentitive to throttle position and could make this noise. when on low throttle the sounds goes away but floor it and its really noisy!
    Any likely candidates? i'm baffled
    I did have a quick check that nothing was hanging out the fuse plate - i wonder if there is a poor connection or short somewhere.
    David
    1992 3b S2 Coupe
  • A80Avant
    • 10873
    • Country: Greece
    maybe one of the vaccum hoses leaking? it does become apparent if you take the carpet/ noise dampenings out.
    i have my ECU hanging out now and you can hear clicking from time to time
      Wierd. As per A80, check thine vacuum lines and also groundeth thine ECU well my son.
      • s2driveruk
        • 12696
        i'll get my head under the dash and see if its anything obvious but its definately a strange noise for sure
        1992 3b S2 Coupe
        • Ross
          • Aug 2005
          • 3399
          not while flooring it I hope... could be a rather comprimising position if you get someone to help out as well... "officer, she had her head in my lap while i was pumping on and off the throttle so she could hear my relay"...
            Sound as sensible as hawking the boost gauge on a 3rd gear run...
            • s2driveruk
              • 12696
              lol
              1992 3b S2 Coupe
              • Al Wyn
                • Nov 2006
                • 3746
                Thats not going to happen...Davids married with children all that nasty dirty business finishes after child number one didnt you know that Ross
                S2 + RS2 yep ive had a few love em... Laser red S2 avant... Brilliant black lhd RS2... Polar silver RS2... RS blau RS2... CheeRS Al
                • s2driveruk
                  • 12696
                  oh how true....
                  Now, whats causing this bloody problem under my dash
                  1992 3b S2 Coupe
                  • s2driveruk
                    • 12696
                    bump.....
                    any ideas?
                    1992 3b S2 Coupe
                    • s2driveruk
                      • 12696
                      ok, this is really starting to get me down about the car, had half the centre console out and a) i can still here it and b) no closer to solving it.
                      Anyone else have any other potential pointers on what could cause noises in that area?
                      1992 3b S2 Coupe
                        I'm starting to remove the sound deadening to either replace or remove completely. Wonder what I'll start to hear
                        • s2driveruk
                          • 12696
                          i am sans deadening felt and you can hear everything Some of it i'm sure is normal, this particular issue i have is not i'm pretty sure
                          1992 3b S2 Coupe
                          • Acidburn
                            • 13459
                            @david - you around next friday afternoon say around 3 ish and i'll come down have a look for you.
                            • s2driveruk
                              • 12696
                              no sorry Pete will be at Festival of Speed
                              1992 3b S2 Coupe
