I know one can replace the standard front wiper relay for a Duduco programable intermittent front wiper relay, but on the later model B4 Cabrio, ( 99 V6 ABC ), they have a wiper stalk that incorporates a 4 / 5 position little switch that alters the delay on the frequency of the operation of the front wipers in the intermittent position.
What I was wondering was that if I fitted such a wiper stalk, would I then have this facility on my 95 Avant or is there more to it than than ?
While the programmable relay is very simple to instal and easy enough to use, the little switch on the stalk is even easier to use, but will be harder to install.
But just in case you have not got a Dudoco relay installed, I'd recommend them as a minimum.
I also need to get a couple of those "comfort" indicator relays that were mentioned a while ago as part of a group buy, maybe somebody could post a link to the thread on this thread for convenience ?. If anyone bought and fitted such a relay to their Avant, how did they get on / find it in operation ?
Hope the above is of interest.
Thanks either way.
Thanks either way.
of a corrado.
