ABY Wiring Harness Help/Identification
This is a sticky topic.
  • jonn48
    replied
    Originally posted by PeterS
    Martin, PM me your email address. Paul's pdf is 7MB, the current forum upload limit is 5MB.
    Is it possible to get this file by e-mail too?
  • martinjs
    replied
    Ok will do.
    thanks
  • PeterS
    replied
    Originally posted by martinjs
    Can anyone confirm what the connector in the 5th picture in the first post in this thread is for? (The one being held)
    I've just refitted my heater box and just noticed it, I can't remember disconnecting it, is it not used?
    On a side note Paul's excellent PDF in this thread isn't accessible anymore, did anyone save it?
  • martinjs
    replied
    replied
    I finally got around to sorting this out today, its very simple actually. If anyone needs to know how drop me a PM
    replied
    Thanks I'll take a look at that, as Paul didn't publish the details on S2Central.
    My ECU is non-immob so as long as the relay can be by-passed its no problem
  • twoqu
    replied
    There is a diagram in the RS2 Motronic workshop manual on Mike's S2 site but it does not have the same colour wiring.
    I'm not saying it is, but if you know you have an immo loom then its a possibility.
    Not sure about the other questions. Try me again in a year unless anyone else pipes up!
    replied
    OK so it is the connector for the anti-theft relay. Does anyone have a wiring diagram for this circuit?
    Can I just leave it unplugged, or do I need a relay and if so what number it is and what triggers it?
  • twoqu
    replied
    Or look at posts 86 & 87 for a possible clue!
  • twoqu
    replied
    Set your MM to ohms and stick one probe in a socket on the connector and try and find continuity somewhere else! The wire colours should help to identify where to stick the other probe. Make a list of what goes where and it might become apparent! Bit boring but shouldn't take a year to complete. That is if you want to find out.
    replied
    Yearly bump! Can anyone tell me what this is red plug is for?
    replied
    Bump to an old thread. I've been marking up my ABY engine loom and came across this off red relay plate that doesn't appear to be mentioned in this thread, but is part of my ABY loom. It is part of the fuse board cluster, connections are:
    Pin 2 - black/green x 2
    Pin4 - black/green
    Pin 6 - brown/blue
    Pin 8 - black/grey
    Can anyone tell me what this is for?
    Alex
  • tajgreidotu
    replied
    Hi all,
    Looking at the schemes, I feel like t5h is not present in 3b cars. I notice it because I cannot find it in my car, and in schemes I always find " *cars from 10/93"
    Am I correct?
  • Ruffiano
    replied
    yes you need it.
  • marson
    replied
    ok thanks, i´ve found the document. do i need this when i have a NG coupe without bordcomputer.
