I'm losing the plot with this one. The dipped headlights keep failing on my 7A Coupe Quattro 20V. I'm on my 3rd steering control stalk. Side lights, full beam, indicators - in fact everything works normally, but every 3-6 months I totally lose dip beam - and nothing else. I have had wiring checked and switches replaced and at a loss what the root cause of the problem is. Is it a relay (none shown in diag) or an earth issue?
The switches show no sign of damage, and I'm beginning to think I am replacing perfectly good column switches and some how curing or resetting somthing by dismantling it all and replacing the damn thing.
I hardly use the car at night, so nothing is burning out and no other services on the control column ever play up (washers, rear wipe, indictors, park lights etc etc). Just the damned dip beam every time. I spend my time driving around at night on the fog lights. Also, the dip beam has never failed whilst driving. It is somthing that stops when the lights are first put on. Give us a clue someone!
If you make sure its clean and the contacts are making a good circuit then it should be fine. Try to close the female side of the contact up a little so you get some pressure on the pin. A little dab of silicon dielectic grease on the contacts will keep the moisture out, from Maplins or RS or you can use plumbers silicon grease from Wickes or B&Q plumbing section.
