I'm trying to get the S2 through it's MOT today but I'm having trouble with the main beam on my ellipsoids. Pull back the stalk to 'flash' and they come on fine but push it forward for normal high beam and they don't ( dips stay on ).
All the indications are that it is the switch itself but I've had it apart and can't see anything wrong. I've given the contacts a clean where I could and all looks OK in the connector plug as well.
It would be logical for the the feed from the switch to the lights to be the same for flash and normal main beam but could it be a separate circuit - is there anything else I should be checking between the switch and the lights ?
Can I assume that if the flash function is OK that it must be the switch or connector ?
Just going to pick up some new A8 discs to try and finish off the 996 front brakes for the MOT as well but it's not going to pass without main beam
Was trying to get it all done for Combe but it's not looking good.
