Whenever I drive my car enthusiastically the brake ( ! ) warning comes on the dash and beeps, the brake fluid is plenty above minimum so my owners manual says its likely something wrong somewhere else in the depths of the electrics... Is it likely to be just a split wire or something actually wrong, how much does this matter?
Also, earlier my ABS switch packed up, I can no longer switch it off, it still switches off with the diff lock button but not on the dash. Just the switch at fault?
Ta!
Ta!
