I have just got myself some heated washer jets and was just wondering how they can be wired easily , can I just run them from a 12 volt source with a switch or do they have to have a resistor
wired in-line with them or something.
what about wiring them off the rear window/side mirror heater switch....
I'm no electrician - but I thinks that's a 30 Amp loop and should give enough power to run all of them together...
In another thread someone mentioned that these when factory fitted are on constantly... which is why they (& MK2 Golf ones) never seem to work for long...
Keep us updated!!! As I may fit them to mine if its not to much work...
yes seem to remember they run constantly which is a bit stupid in the middle of July in 30 degree heat having them pump away Keeping an eye on this as I would like to change mine if its a doddle too
