ok to solder connections on battery cable?
    I need to make up a new power cable from battery to fuse board. Will be using 25mm2 cable and wanted to re-use the terminals off my existing cable - is it ok to solder and heat shrink the connections given the high current etc?
    I only know enough about electrics to fill a postage stamp
  • Flat on my back
    • Jan 2007
    • 2449
    Soldering that size may prove difficult, cant you get a crimp terminal fitted...most decent car auto/audio places should be able to do it.
    Carlos.
      not a problem on the battery end but the fuse board end isn't an off the shelf connection
      I've got a mini blow torch i've used for big calbe before
      did you get that package BTW dude?
        Ahha: I might just get a couple of these
        • Flat on my back
          • Jan 2007
          • 2449
          Can you open out the 'terminal' and re-crimp your new wire?
          Piccies.
          Carlos.
            always ends up messy when i've tried that before on terminals
            • Flat on my back
              • Jan 2007
              • 2449
              Perfect job, heat shrink over the top and jobs a gud un.
              Carlos.
              • pixsaudisex2
                • Sep 2004
                • 3110
                Most stereo shops will have lovely big gold clamps..:mischeif:
                • a4kquattro
                  • Feb 2005
                  • 411
                  yep. for huge gauge cable I use crimp lugs like the one posted above. crimp, then heat with a blowtorch until the solder flows in, then pack it with solder. cover with heat shrink. failproof connection.
                  Marc Swanson
                  Proprietor, EFI Express
                  95.5 //S6 Avant
                  90' Coupe Quattro V8 4.2L twin turbo
                  93' //S4
                  83' UrQ
                  97' F250 7.3 diesel
                  • borderS2
                    • Jul 2008
                    • 166
                    These are available
                    S2 91 (red standard)
                      yup, like i said its the fuse board end that is an oldball terminal
                      I'm gonna use the butt end joiners and some shrink wrap
