I got to the bottom of why MAF, ISV and so on get 12V when the key is ON... they are not only activated when the engine is running. I couldn't see it at first, but one of the ECU pins is taken to 12V when it is powered up. The common connection is AFTER fuses 24 and 28 which is all a bit strange but it explains that weirdness we saw last week when I thought only the fuel pump relay triggered these. I need to dig more to see if the ECU always holds this pin high or whether its part of a start sequence which times out unless the ECU sees some flywheel teeth.
It might also be related to MAF burnoff, but this pin is also part of afterrun logic as well.
