I want to recalibrate my speedo if its at all possible, so it reads right rather than 10-15% under - is it possible?
Recalibrate speedo?
I got a few interesting answers when I asked the same question some months back.
HTHShaneComment
Nope, they're not, the CQ is 5% different, just look at the position of the 160 marker, it's further round on the CQ
Theres quite a few different speedos but i seam to remember the 7a ones where the same.
I even found a UN4 cluster the other day that i had left over with 160mph range.
Very unusual as the UN4 ones are usually 140mph.
I think the easiest recalibration would be a resistor in the speed sensor wire.
Other then that i dont think there is any physical adjustments on the cluster.91 S2 coupé - RIP
98 S8 - Luxury bargeComment
The speed sender generates a pulse train - adding resistors to it will not change that. ThesE pulses end up in the speedo module where a special chip drives the mechanical speedo and odometer - ime these always read slightly high in all cars for safety reasons. The chip in the speedo has a few supporting components that configure how it drives the gauge. Trouble is that it's not at all easy to unpick this from back of the cluster.
The speedo chip also generates the vss signal which goes to ecu, abs, rdl, radio/gala and cruise etc. Vss can bE logged on obd and along with a calibrated gps sensor would be possible to skew that result for better accuracy - but that doesn't help reading the speedo - if speedo comp changes are not possible then it would be interesting to have aftermarket gauges setup fo correct position as fond by gps test runs.Paul Nugent
i kinda vaguely remember there were 3 pins behind the instrument cluster +-/ 5/ 10 % for the adjustment... may be remembering it from another car thou
