Voltage drop in Reverse
  • Bowlerwell
    • 1052
    Originally posted by UrS4boy
    It will dip until you take the trans out of reverse. There is some kind of memory because it returned to the previously adjusted position.
    Yep, My BMW had this feature.
    I'm just wondering if it's possible on the RS2...
    If the controller simply winds 'down' for x time, then 'up' for x time, then this function should be implementable.
    If the controller looks for positional feedback from the mirror, then I fear this might not be possible with my mirrors...
    I think the latter is more likely...
    John Bowlerwell
    Electronic Engineer
    Present:
    Nogaro Blue RS2 - TOE
    Previous:
    Kingfisher Blue S2 - UAA
    Volcano Black RS2 LHD - DEX
    • Mikes2
      • 1704
      Mike
      http://www.s2-audi.co.uk
      • Dan
        • Jun 2008
        • 1242
        Well, in theory it might not be too hard to knock something up as a ghetto aftermarket* - if there's nothing we can steal off the urS4.
        Any S4 guys know how theirs works?
        * I am drunk. All electronic/programming tasks seem easier when drunk. Just need a transistor and a for loop.
        1993 ABY Coupe | BMW R1200 GS
        A6 3.0 TDI Quattro (aka Sonic's 'ring support/cargo vehicle )
        • Al Wyn
          • Nov 2006
          • 3746
          What you need to suss this out John is an electrical engineer
          S2 + RS2 yep ive had a few love em... Laser red S2 avant... Brilliant black lhd RS2... Polar silver RS2... RS blau RS2... CheeRS Al
            As I suspected the clue is in the fuse data..
            Fuse 12 - Instrument cluster, reverse lights, fast idle, multiple sensor, GRA, distance sensor, airbag warning lamp
            So the volt meter runs off the same circuit as the reversing lights hence the volage drop when they're on. I'd bet you wouldn't see nearly as much drop at the battery terminals.
            • Bowlerwell
              • 1052
              Interesting. That'll be it.
              I sort of assumed that the voltmeter would show the voltage of the battery, rather than one specific fuse branch. Every day's a school day.
              John Bowlerwell
              Electronic Engineer
              Present:
              Previous:
                Its known as convenience wiring
