Took the coupe out tonight, first thing I notice as I shift into second, no speedo. Its not stuck on the face as it has plasmas. the rest of the cluster seems to be working ok so I guess its not a fuse.
Speedo stopped working!
Tags: None -
Mmm, odometer, need to check that
Tried smacking the dash, no go. Will check the odo.Comment
Odometer is still working so the problem must be in the cluster, I'll try the spare one I have in the garageComment
Ours does this a couple of times a year, all I do is press the small (I believe) fuel gauge calibration button. It must just exert pressure on a PCB dry joint or something, because it works fine again for months.85 WR Urquattro, 85 20vT International liveried RallyRep
93 MTMS2 Avant
Had this one intermittently before as well, when the odometer was also not working.
Giving the connectors into the instrument cluster a good clean and making sure they were all clicked in correctly seemed to fix the problem, at least i've not had it happen since.S2Forum.com AdministratorComment
I've had this several times, Both times fixed by stripping clocks, and resoldering connector plug from loom to clocks, Been brokes solder joint both times as I couls see it. A good time to replace the bulbs while you are at it
Paul1995 RS2 Nogaro
1971 Lotus Elan Sprint
1974 Lotus Elan+2S 130/5Comment
funny enouth my packed up last
very strange that.it must be something to do with the heatwave we're having.it getting checked as we speak,hopefully it can be solted.can't afford to have it not working with all this camera's about.
[SIGPIC][SIGPIC]/SIGPIC]92 3B pearl white=gone back home to Germany,probably in bits and pieces
RS2 VOLCANO BLACK] soon to be broken to bits
