1991 3b S2 Electric Window Problem
  • audimaniac
    • Feb 2007
    • 152
    Hi to all, i seem to have an anoying problem with the passenger side electric window which seems to have a mind of its own.
    The window goes all the way down but will Not return back up the switches are unresponsive???
    Changed window relay still same, stripped motor and looks ok, checked cable all free?? tried a spare motor i have and still the same??
    Anyone come across this before??
    Cheers in advance for any help please.
  • Tony Stark
    • Nov 2009
    • 288
    Mine did this shortly after i got it. Popped a spare passenger side switch in and its been fine since.
      S2 Central posted a wiring diagram for these, it does sound like a switch issue to me.
      • simon20vq
        • Dec 2010
        • 1379
        There are two 20amp fuses under the dash. They are metal. I think one of those is your problem. swap them around and see if the issue changes to the drivers side if it does head up the scrapy and you can find them fitted in golfs of that age.
        • LSG
          • May 2010
          • 898
          I had a problem with my windows.I did use the s2 central wireing info realy helped.I could see all the switches were doing what they should.I had a look at the motor and where the plastic wheel inside sits on the metal pin it had rusted so makeing it slow to go up some times working then not.Did do my head in a little.I covered it in oil and worked it up and down till i was happy with it. It was a bit of a pain in the b-m but its still working fine.Hope this helps and you get it sorted out. Regards Lynn,S,Guildford.
