Bulbs for Instrument cluster and aux gauges
  • Jonnybravo
    • Aug 2008
    • 2051
    Simple question, where is best to source a few new bulbs from ? I'm sure the one in the auxillary gauge is just like the ones that Vauxhall used and I have got some somewhere but can't seem to find them right now.
    I think its the ambient temp that needs replacing if their any different ?
    Are they available through the dealers or would a motor factors have them ?
  • mcandmar
    • Apr 2004
    • 5118
    I have seen them on ebay, and i think they are listed in the Maplins catalog. As far as i know they are a standard automotive part so motor factors should be able to source them too. Ambient temp display has soldered in bulbs, available from ebay or Maplins.
    91CQ20v - Gone to a new home
    93UR-S4 - The Magic Carpet
    94S2Bus - The Emerald Express
    • JP
      • 1858
      bought mine from a main dealer. there's different powered ones too. If you check in your clocks which ones are the 1.5 or 2 watt ones and order those for all the dials then you instantly have a brightness upgrade too
      UrS6 Stroker + HTA3586 =
      • simon20vq
        • Dec 2010
        • 1379
        Ebay about 2 quid for 10!
        • Fat Audi 80
          • 10547
          Be careful with the high wattage dash bulbs. I believe there is a theory that the extra heat can lead to the clusters peeling. I would recommend staying with the correct wattage if you can....
          The Perfectionist
          • Jonnybravo
            • Aug 2008
            • 2051
            Thanks for the info guys. I'll have a look for the ones I need and get then ordered.
            • mcandmar
              • Apr 2004
              • 5118
              Agree with Steve, dont fit higher rated bulbs. I even melted the inside of a fog light switch with a higher watt bulb.
              • haaran
                • Apr 2009
                • 236
                Have a look here...
                Shop car bulbs, headlights, and automotive lighting online. Huge range for all vehicles, fast UK delivery, premium brands, and expert support.
                Audi S2 Avant, 1995, ...and it begins with a Homefry
                Audi 80 Sport, 1986, ...my first car...wish I still had it
                • j_jza80
                  • Feb 2011
                  • 229
                  Do the replacement bulbs all require soldering in, or is there a like for like swap?
                  EX S2 ABY owner, now driving a BMW E39 530D manual & a MK1 Golf GTi called 'Hattie'
                  My second Supra, a very special 1997 RZ-S 6 speed single
                  • simon20vq
                    • Dec 2010
                    • 1379
                    If its for the cluster on dash or aux gauges they just push in, if for switchs I believe you need to solder
                    • Roach
                      • Jul 2008
                      • 107
                      Got mine from main dealer orange ones part no 893 919 040 c,white ones 4A0 919 040 c
                      • j_jza80
                        • Feb 2011
                        • 229
                        They're from the dial cluster, I need one clear, and the one from the ambient temp display is missing so I'm not sure what colour I need, though I suspect it's orange.
                        • j_jza80
                          • Feb 2011
                          • 229
                          Has anyone an idea of the cost of these? Tia.
                          • mcandmar
                            • Apr 2004
                            • 5118
                            Not sure of the cost but can be bought on ebay or from main dealer. There are a few different ratings, 1.1w, 1.2w, and 2w bulbs, each type has a different colour base. I "think" the main cluster uses 1.1w bulbs with an orange base. Outside temperature gauge needs taken apart and a new bulb soldered in place.
                            • j_jza80
                              • Feb 2011
                              • 229
                              The ones in mine have able base. (goes off to eBay...) thanks
