I am very sorry, for you Guys.
But have have to say, that when i designed this Manifold over 5 years ago, i did the testfitment only with OEM Parts, as Turbos and Downpipes.
And everything did fit well, as many People can vouche for.
I can not check every Aftermarket Downpipe for perfect fitment, with our Manifold, sorry.
Designing Performance Parts means also maxing out the Tolerances, and when a other Part is maxed out to the oposite Way, you will may run into some fitment Trouble.
@Rusty, regarding your Waterlines, as i told you already on the Phone, i believe that your Turbo Middle section is not adjusted in the right angle, so in that case you run into fitment problems. You can adjust that by yourself or have somebody with experience do that.
At least it's a complete animal of an EM :mischeif:
My main beam lights DO work as expected.
