Wiper linkage rebuild
This is a sticky topic.
    • 4754
    Superb thread and relevant to all of us.Talent on here never ceases to amaze!
    • s2driveruk
      • 12696
      Any chance you have the images still about to embark on this one
      1992 3b S2 Coupe
        Yes I think so... will check this morning and upload if I have
        • s2driveruk
          • 12696
          Nice one, thanks mate
          1992 3b S2 Coupe
            Done
            • s2driveruk
              • 12696
              Fantastic...off to get started!
              1992 3b S2 Coupe
                Have fun
                • s2driveruk
                  • 12696
                  Thanks the pictures made this all the easier. Managed to get it out and on the bench, was a bit crusty generally and the spindles seemed like ther were very dry, which made the whole assembly hard to articulate. The actual motor was a bit waxy grease wise but not as bad as i was expecting. Had a couple of issues reinstalling it back as hadnt remembered to re-align everything properly, so first flick on the stalk sent then south to the scuttle
                  quick tip if you forget how to align, plug it in, let it do a sweep, then you can undo the nut holding the mechanism to crank arm, then basically realign the crank so it is in the 3 oclock position, then retighten. Might find it easier to take the assmbly out again to do it...
                  1992 3b S2 Coupe
                  • s2driveruk
                    • 12696
                    Any other areas to check, my motor is cleaned up and seemingly working just fine but the power to work the wipers is just not where i am expecting it to be. Any good ways to confirm the relative health of the motor itself or any compatible newer units, as visually many ‘look’ the same but advice welcome.
                    1992 3b S2 Coupe
                    • Pat D
                      • Dec 2011
                      • 748
                      • Country: Australia
                      #25
                      Excellent, its been around 8 yrs now since pulling mine apart, along with the rest of the car still in pieces. I cringe every time I see this thing on the garage floor waiting to be rebuilt, this sticky will make things easier.
                      ABY S2 stroker (work in progress)
                      B5 1.8T quattro
                      B4 2.3 (decommissioned)
                        Another job to go on the list...
                        • s2driveruk
                          • 12696
                          Drove the car the other day and they appeared to be working better this time, maybe i will wait a bit longer but still be good to see if any other units x-match for future...
                          1992 3b S2 Coupe
