Regulator woes
  • sidrick
    • Jan 2011
    • 1342
    Regulator woes
    Looking for some advice, dear forum, as the coupe is in last chance saloon.
    After shelling out near dealer prices for a new driver side regulator when mine packed in, I discovered that I'd bought the wrong one (for the later coupe rather than for my B3 1991).
    I searched high and low and had a number of let downs from breakers in the UK before forum member Nik0las () helped me out and shipped one from Bulgaria to me. I went to fit it today, and unless I'm being stupid (quite likely) I can't see how the motor can fit
    Can anyone advise WTF I need to do to make it fit or if it's completely wrong? I don't know if I can buy a 3rd regulator at more than £100 per time
    Replacement regulator motor mounting:
    Current fitted regulator:
  • SteveH
    • 4460
    The one you have fitted to your car looks like all the others I've seen. The replacement looks like a manual winder unless I'm mistaken?
    Unless it attaches to a different motor?
    91 Modded 3B
    14 A6 Avant Black Edition
    • djh
      • Jun 2011
      • 1622
      • Home: United States Current: United Kingdom
      not good thats a manual window motor, won't work unfortunately.
      but on the plus side rare as hell, i've never seen one.
      • gripper
        • Jun 2008
        • 1156
        I feel your pain Sidrick !
        I've owned my coupe around 5 years now and replaced the window mech 3 times but actually bought around 5 of them
        A lot of people think they are interchangeable but they are not because the top bar of the framework is contoured differently
        For what this cost me so far I could have bought an S2
        • willg54
          • Jun 2009
          • 2055
          whats the part number of the one you need?
          1996 Audi S2 - 295bhp and 326lb/ft - Complete Rebuild Project
          1994 Audi 80 - 2.0 8v (slow but reliable!)
          • sidrick
            • Jan 2011
            • 1342
            Quite sure it's 895837398A.
            • sidrick
              • Jan 2011
              • 1342
              Amen to that. Since mine is a late 91 it seems to be on a chassis break for just about everything and I have to wade through a sea of misinformation online and sellers who don't know their **** from their elbow (hopefully this instance was an honest mistake).
              It's depressing for something as small as an electic window to have kept my car off the road for about 6 weeks now. £160 for the first regulator, £50 fitting for it, £137 on this second one..... that could have had me a set of B6's almost
              • spink
                • 4382
                I know its 100plus miles from you but there was 2x b3 coupes in upullit inverkeithing 2 weeks back when i popped in,both had offside mechs in them still.totally forgot you were needing one.hopefully they havnt been binned already as my local one is savage at slaughtering off complete cars after only a week or so
                  What's wrong with the one you have there with the motor on it? I wonder if you could swap the cables and motor over? Or are the cables the same length on the manual one? if so maybe you could swap the motor and the gearbox winder bit..
                  I repaired the driver's side one on my ur with a bicycle brake cable. I was a right fiddle but its still going strong after a few years..
                  • sidrick
                    • Jan 2011
                    • 1342
                    The one with the motor on it is the later regulator that doesnt properly fit the door frame.
                    • johne
                      • Apr 2007
                      • 1406
                      but is the cable and drum on its own NLA? 'cause if it isn't this would seem to be the easier way to go and avoid your specific regulator problems.
                      When I had to repair mine a few years ago I just bought a new cable and drum for around £50 and then fitted it to the old regulator mechanism and motor with the help of some very useful photo heavy helpful postings on here. Part number 895 837 726B. You do need a 1/4 or 3/8th 11mm socket slit up the side to fit it but I'm happy to send you the one I butchered
                      John
