Noisy Bosch 044 Motorsport Fuel Pump
  • prj
    • Mar 2010
    • 6308
    Originally posted by Rocco
    you will see how hard it is also mine with everything solid
    • Rocco
      • Aug 2007
      • 6393
      • Country: Spain
      Originally posted by prj
      you only read what your mad mind wants
      edit ( you might know Rocco Tano.. Siffredi second name as his artistic name ) he could do the job for you
      • dobbin
        • Jan 2011
        • 164
        rs2 pump
        i had same problem as well so i took the check valve off walbro pump and fitted a rubber petrol hose inside tank to cut down vibrations instead of solid plastic pipe .
        this works well on my rs2 much quieter now. i had to get new banjo bolts to make everything fit from ebay. also im interested in your turbo conversion \upgrade can you give me details ie bhp torque who i need to contact
        • mcandmar
          • Apr 2004
          • 5118
          Curious, i found the 044 pump quieter inside the car vs the stock pump, but noisier when standing outside the car.
          91CQ20v - Gone to a new home
          93UR-S4 - The Magic Carpet
          94S2Bus - The Emerald Express
          • Avantus
            • Sep 2007
            • 941
            • Country: Belgium
            #20
            Mine was sounding a a bit like bubbling air now and then. Now with my new fuel lines from tank to engine that's gone lol :
            Certainly a bit louder than stock, but nothing major. From what I've read they can be noisy, without any danger?
