For those not familiar with this bit of kit its basically a VAG version of the Nazi Enigma Machine. Rather than just expressing a resistance as a particular ohms rating, the VW 1301 is to be used instead. Unfortunately the required setting on the VW 1301 was not the actual value in ohms, so using factory documentation to test something was a bit problematic. I have just stumbled accross this:
Hopefuly that should allow the subsitution of a fixed valued resistor to simulate the VW 1301. If somebody with better computer skills can capture the chart and post it, then perhaps we can sticky it as a reference.
