aux gauges not lit
  • Gazmitchell
    • Feb 2013
    • 640
    aux gauges not lit
    Hi all
    two of the three gauges not back lit when lights are on, so want to sort em out, any ideas before I start to push me in the right direction ? thanks your help
    Gary
  • K Simmonds
    • Dec 2007
    • 7632
    If one still lights up then the bulbs have failed in the other two. It's a little bit of a fiddle but their easy enough to change.
    1990 B3 2.0 80 quattro.
    1992 C4 2.8 Avant quattro
    1994 MTM RS2.
    1998 B5 TDI quattro Sport.
    2000 B5 TQS.
    • sidrick
      • Jan 2011
      • 1342
      I had this in my old coupe, one was not lit, but still worked. Even after replacing the bulb and eventually the guages (they were flaking anyway) one still wouldn't illuminate.
      There's a relay-looking 'illumination booster' behind the guages. Replacing this sorted mine. I've a spare if you diagnose this as the problem.
      Must be #9 in this pic IIRC and is in the loom for the aux gauges:
      You can see it in the photo that a user has posted in his for sale thread
      • Gazmitchell
        • Feb 2013
        • 640
        Ok thanks guys , will check it out..
        • Monkeymagic
          • Mar 2012
          • 3419
          check your reg plate lights are on. the fuse for these also does the aux guage illumination. the glove box switch in mine shorts and pops the fuse. Think it common and seem to think it fuse 5... or might be 5 amp fuse.
          • Monkeymagic
            • Mar 2012
            • 3419
            scrap that just read it properly most likely bulbs.
