Rear light connector wiring
  • bungle74
    • Nov 2011
    • 87
    I'm having issues with my drivers side rear light. I believe there is a short as the indicator isn't working all the time and when I brake the rear light goes off and the indicator light comes on. It looks like this is down to the 2 wires that go into the same connector in the picture below. I believe on wire may be for the rear light & the other goes off to the indicator. Wiggling these 2 wires causes the indicator to work/not work so really need to get the wires disconnected to see what is going on.
    I can't see how to get the connector off, does the connector on the wire pull out or do all the wires plug into 1 big connector?
    Lee
  • bazburn
    • Feb 2010
    • 583
    Cleaning the kak off just above the connector might fix your problem...
    • bungle74
      • Nov 2011
      • 87
      I've replaced the bulb holder with a spare one I had without any crap on it and still have the same problem......good spot though!!
      • _ShurikeN
        • Mar 2010
        • 733
        • Country: Russian Federation
        Take the black jack, unclip and raise up the small lower panel (where partnumber is casted) and some details will be visible.
        • bungle74
          • Nov 2011
          • 87
          I'll take another look tomorrow, I looked under the flap yesterday but couldn't see if the connector would come out. What I don't want to do is break anything!! However, the Old Bill are hot on tail lights round here at the moment so need to get it sorted this weekend.
          • bungle74
            • Nov 2011
            • 87
            turns out the replacement one also had crap on it so i cleaned the original up and Hey Presto!! all works as expected......cheers once again for the help.
            Lee
            • bazburn
              • Feb 2010
              • 583
              Good your fixed...
