Crank reluctor sensor
  • Pat D
    • Dec 2011
    • 748
    • Country: Australia
    I'm trying to confirm whether the later model VW crank reluctor sensors such as the one I have here operate the same as the S2 sensor on the flywheel.
    Something like this?
    Pin 1- 0v reference
    Pin 2- Signal
    Pin 3- Ground
    Anyone else know much about these sensors?
    ABY S2 stroker (work in progress)
    B5 1.8T quattro
    B4 2.3 (decommissioned)
    I guess you'd need to test them on an oscilloscope to be sure, but maybe Prj knows?
    • Pat D
      • Dec 2011
      • 748
      I did some reading and as I understand there must be a coil inside with the permanent magnet, the dc resistance on pins 1 and 2 showed this. I might take it to work when I'm there next and test it with the cro to make sure.
      B5 1.8T quattro
        G4 crank position and G28 engine speed sender info
        Originally posted by Pat D
        I'm trying to confirm whether the later model VW crank reluctor sensors such as the one I have here operate the same as the S2 sensor on the flywheel. Anyone else know much about these sensors?
        This is what I know (without checking the Bentley):
        • Pat D
          • Dec 2011
          • 748
          http://forums.quattroworld.com/s4s6/msgs/20986.phtml
          Cheers for that info I'm measuring similar values across pins 1 and 2 , but reading about 25mohm across pin 3 to both other pins. I'll see how I go when I take it into work for testing.
          B5 1.8T quattro
