I have a similar problem on my S2 Avant that used to happen on my Coupe, upon entry and start up the electric windows don't work, but after around a minute or sometimes a bit longer they start working??
Even more annoying now they stopped working all together and one rear window is stuck half open
and even more annoying its now Fr*ckin raining
My S2 ownership goes from one problem to another
Any ideas please people?
Check the relay, and also given the weather in the UK right now you can try changing the thermal fuse, this will disable all windows and the sunroof if it decides to
I'll have a look when it stops raining, I'm certainly not driving it with a bag taped over the window, not a great look, although I'd probably prefer to drive it like that than drive this car lol...
oh, i cut the protective cover back but a pin should poke through the cover then just stick 12v to that
